Page 5 of 27
FirstFirst ... 3 4 5 6 7 15 ... LastLast
Results 121 to 150 of 793
  1. Originally Posted by mahone View Post
    Hi,
    I´m trying to get the keys from the provider NOS.TV from Portugal.
    It doesn´t work, i know that is not some kind of bug neither errors, but something is missing.
    Reading the networks packets i see that the error 401 Unauthorized is present.
    Here´s the info
    Try with only the nv-authorizations header. The right license url should be:
    https://nos71zv1.anycast.nagra.com/NOS71ZV1/wvls/contentlicenseservice/v1/licenses
    Response should be in json, although that's not your problem (yet).
    Also this is not the right thread to post your problem to, find another thread that talks about NOS, open another one, or PM me.
  2. in order to work properly I have to send complete json because it contains if I remember correctly the PID, but I am not sure
  3. Originally Posted by FoxRefire View Post
    [Announcement]
    Started beta test of new version of this extension🎉
    After beta testing has done, I will focus be on developing new version, and legacy versions will not be actively developed.
    You can try new extension here:
    https://github.com/FoxRefire/wvg/tree/next
    In new version, it dropped WVCore.Server and works with Pyodide+Pywidevine.
    Therefore, extension works standalone and doesn't need external API setup.
    Of cource, you can still continue using of legacy version after beta testing is done here:https://github.com/FoxRefire/wvg/tree/legacy
    I am confused about the file called device.wvd, where do I get that at? or is it one of the files like device_client_id_blob or device_private_key and just rename one of them to device.wvd? thanks
  4. nxhda
    Sep 2022
    Try use this generate a wvd file
    pip install pywidevine
    pywidevine create-device -t ANDROID -l 3 -k device_private_key -c device_client_id_blob
    discord nxhda
  5. I was able to get it with the link he provided. thanks again, it works great.
  6. @FoxRefire
    Great plugin, i have a question if it is possible to add manual "PSSH".
    Aug 2023
    Turkey
    Originally Posted by papa01 View Post
    @FoxRefire
    yes pls
  8. Also can add display the stream URL as well?
    thanks
  9. from Guess i get SIGNING and CONTENT
    content is key, but what is signing ?
  10. Interesting project, thank you for sharing.
  11. Thanks, FoxRefire for this project
  12. Good morning,
    I tried with Firefox to obtain the key but it doesn't work on M6 Replay.
    [Attachment 78515 - Click to enlarge]
    with bitmovin video it works.
  13. I am fed up with such unproductive PMs that arrive frequently
    @FoxRefire,
    Go to your profile settings and turn off all PM's. This is an easy fix and I think that it will benefit you.
    Thanks for the share and your patience.
  14. [Announcement]
    Extension updated.It supports more CDM file types not only device.wvd.
    * Supported CDM Types
    1. device.wvd
    2. device_client_id_blob + device_private_key
    3. client_id.bin + private_key.pem
    Also, I added guide for contributors.If you want to contribute this project, look for it.
    https://github.com/FoxRefire/wvg/blob/next/CONTRIBUTION.md
    PS: Thanks @jack_666
  15. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    I am fed up with such unproductive PMs that arrive frequently, so I decided to create a rule of here.
    Does that include the DM I sent you?
  16. > Does that include the DM I sent you?
    Nope,I appreciate you for providing the scheme for the old version of the extension and for your suggestions of UI improvement.
    However, I am not going to merge your UI improvement suggestions into my code, as I was a bit unsatisfied with them.
  17. [Announcement]
    DRMToday scheme has also been added to the new version of the extension.
    https://github.com/FoxRefire/wvg/commit/f98c2b1781770c96d507f7800d87689fa1e305b0
    You can test it here.
    https://demo.castlabs.com/
  18. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    My version of your "legacy" extension attempts to automatically select the correct license server, do you want that code snipper or not needed?
  19. @FoxRefire any thoughts about adding sites that has M3u8 + Keys to the guesser to pull from those type of streams? thanks
  20. The stream type, such as MPD or M3U8, does not matter if the extension is available at the site or not.
    What is important is whether the license wrapping scheme used by the license server is supported by the extension.
    https://online.familyclub.jp/s/jno/page/live_player_test
    For example, this site uses m3u8 for its streaming format, however which uses common licensing scheme, so extension is available to use.
    And Rule 2, You must submit scheme when specific website inclusion request.
    Schemes is in python/schemes directory.
  21. Originally Posted by FoxRefire View Post
    The stream type, such as HLS or M3U8, does not matter if the extension is available at the site or not.
    the extension is available to use, it displays the PSSH and License server, but when I click on guesser, it will not display the key, the Guesser works on other sites that have MPD, and not this site that uses M3u8 so far. any help on this would be great.
  22. Image
    [Attachment 78538 - Click to enlarge]
    Works on my side.If not for you, this is bug.
    Read the rules in the first post and do what you should do.
  23. I never said that site you posted didn't work, I am saying the one I am trying to get to work with M3u8 + keys is not working.
  24. Originally Posted by Karoolus View Post
    Yes,Automatic detection of license URLs is one of the features I plan to add in the future.
    Thanks Karoolus.
  25. Hello everyone,
    I tried the link you posted, it works.
    [Attachment 78541 - Click to enlarge]
    I tried on M6 replay it doesn't work because I can't get the key even on TF1 replay application shows me widevine is not detectable.
    [Attachment 78542 - Click to enlarge]
  26. @sesamap159
    Send me init data of EME logger
  27. Member
    Aug 2023
    Turkey
    pyodide.asm.js:9 Uncaught (in promise) PythonError: Traceback (most recent call last):
    File "/lib/python3.11/site-packages/pywidevine/cdm.py", line 407, in parse_license
    signed_message.ParseFromString(license_message)
    File "/lib/python3.11/site-packages/google/protobuf/message.py", line 199, in ParseFromString
    return self.MergeFromString(serialized)
    File "/lib/python3.11/site-packages/google/protobuf/internal/python_message.py", line 1106, in MergeFromString
    if self._InternalParse(serialized, 0, length) != length:
    File "/lib/python3.11/site-packages/google/protobuf/internal/python_message.py", line 1159, in InternalParse
    (data, new_pos) = decoder._DecodeUnknownField(
    File "/lib/python3.11/site-packages/google/protobuf/internal/decoder.py", line 1003, in _DecodeUnknownField
    raise _DecodeError('Wrong wire type in tag.')
    google.protobuf.message.DecodeError: Wrong wire type in tag.
    During handling of the above exception, another exception occurred:
    File "/lib/python311.zip/_pyodide/_base.py", line 573, in eval_code_async
    await CodeRunner(
    File "/lib/python311.zip/_pyodide/_base.py", line 395, in run_async
    await coroutine
    File "<exec>", line 63, in <module>
    File "/lib/python3.11/site-packages/pywidevine/cdm.py", line 411, in parse_license
    raise InvalidLicenseMessage(f"Could not parse license_message as a SignedMessage, {e}")
    pywidevine.exceptions.InvalidLicenseMessage: Could not parse license_message as a SignedMessage, Wrong wire type in tag.
    at new_error (pyodide.asm.js:9:10014)
    at pyodide.asm.wasm:0x158e62
    at pyodide.asm.wasm:0x15ff9e
    at _PyEM_TrampolineCall_JS (pyodide.asm.js:9:120223)
    at pyodide.asm.wasm:0x1a3494
    at pyodide.asm.wasm:0x28a2bd
    at pyodide.asm.wasm:0x1e431e
    at pyodide.asm.wasm:0x1a397d
    at pyodide.asm.wasm:0x1a3c3e
    at pyodide.asm.wasm:0x1a3ce0
    at pyodide.asm.wasm:0x2689a4
    at pyodide.asm.wasm:0x26e800
    at pyodide.asm.wasm:0x1a3e08
    at pyodide.asm.wasm:0x1a3a98
    at pyodide.asm.wasm:0x15f76b
    at Module.callPyObjectKwargs (pyodide.asm.js:9:64297)
    at Module.callPyObject (pyodide.asm.js:9:65365)
    at wrapper (pyodide.asm.js:9:32855)
    i sure thad the header not coreckt mybe ...
    becouse the request need
    Authorization:
    Bearer
    and
    X-Cb-Ticket:
    bud dont know how or where i have to fix this
